5690 Discussions
Communication PC-De0 Nano with CP2102 TTL
Hello everyone,
I need to make a GUI that could communicate between pc and my De0 nano.
I could make the GUI with QT but I don't know how the communication work.
I have CP2102 TTL but I don't know how to connect my De0 nano, ı don't know also have my board RX, TX pins.
Is there anyone to help?
Thank you everyone.
EDİT: I am using verilog if ıts necessary
1.You can short tx and rx of CP2102 connect it to PC, Now you can use hyper terminal and check the basic communication.
2.From KIT you can use GPIO pin's and connect the CP2102 rx and tx pins.(take care on power).
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
If ıts not so much ı have one more question,
ı have 32 bits output in total in fpga, how can ı send all these bits, should I send one by one or in a bound rate is ıt send a bits pocket (8 by 8 or 16 by 16)?
Can tell me which all IP you are using and how it is interfaced?
You should use packet.(user data is communicating parallelly via avalone interface which is given to uart avalone interface after that IP converts tx/rx serially)
Set proper baud rate in IP and your GUI.
Anand Raj Shankar
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
I am using Qt for ınterface with SerialPort Library. But ı decided to try communicate with already existing ınterface like Realterm or putty. And I guess, ı can not set proper baud rate. Something is wrong with clock in fpga. For ex, basicly for a led blinking code, ı define 2 one bit output. One for led , other for tx. And I turn on the led for 3 sec. Also turn of 3 sec too. But when the led turn off, my ttl send to pc turn on data. I can see the another led on ttl. When led which is on fpga is turn off, ttl led is turn on. It works reverse.
Hi
Check your design.
led are active high configuration in you board.
Anand Raj Shankar
