5475 Discussions
Comparator model in simulink model using DSP BUILDER
Hi all,
I am atttaching 3 files:-
1) simulink model
2) simulink(HIL) model;
3) Error snap while go thru HIL BLOCK.
Now,
i am using DSP BUILDER for some algorithm ..
Before that i am trying my hand on small examples..
one of them is i have attached with this mail..
if i simulate the design in simulink then it works fine..
If when i compile using signal compiler it creates all the required files...
But wen i want to go dumping the code using HIL block ...
It shows the following error..
"ERROR: There are no clocks in the Quartus project sim4 HIL simulation may not work properly with this design. Refer to the HIL Trouble Shooting section of the Reference Manual for more details."
I have tried using even with clock but same message is repeating ...
I think many of u have worked on this ..
so i kindly request u inform ..
what is the problem associated with it....
thanks
regards
raj
guru.koti@gmail.com
bangalore
9886479346
I had the same problem:
For me the problem was solved when I connected the DE2 board while I compiled the simulink model. That is before I press the signal compiler button I connect the board. Then the warnings during the compiling will disappear and you can include the compiled file using the HIL block...
I hope you understand my suggestion else I will try to elaborate on it later on!
