5892 Discussions
Comparison between NIOS II and dual processor Cortex A9 ARM
JEL_W
Hi all,
I have to design, an acquisition chain and do the data processing on FPGA, so i'm quite hesitant between using ARM or NIOS for the design, I know that ARM is a hardcore and NIOS is a softcore, but for more speed, high precision , what is the most optimized processor ?
thank you all
Ahmed_H_Intel1
Hi, NIOS II gives you the flexibility of having multi core (2,3,4,..) and to connect them with peripherals, supports you with the required HAL drivers. The ARM is a hardcore device which you can achive it's performance by having FPGA-SoC device to get the best of two worlds. I recommend you to use one of the FPGA-SoC devices that have FPGA with ARM processor on-chip. Regards.
