I have a FPGA and EPCS flash with socket then begin the following process.
[1]. Config jic file from Quartus II programmer then read its bin from external flash programmer
[2]. Program an empty EPCS though bin file generated in [1] with external flash programmer.
My question is the EPCS content in [1] and [2] is the same, right ?
JW1121,
Yes, it is the same.
However, you need to take the way you program bin into flash (either LSB first or MSB first).
Thanks😉
