I am using two Cyclone 10LP FPGAs (10CL055YF484I7G). I want to know the size of configuration file so that I can select appropriate EPCQ memory
Hi Rafi,
The size is depending on the design itself. I would suggest you to create your design in Quartus and have it compiled. You can know the size from the bit stream generated.
YL
What is the largest size that you could have in the fabric of the part if you were not using external memory at all?
david
Hi David,
119088 is the largest logic elements in Cyclone 10 LP. You may refer to Cyclone 10 LP device overview at link below for more information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51001.p... (Page 5)
YL
