hi
this is more of exploration phase question.
I intend to connect two S10Dx kit over I2C; while one works as master and other as minion. i intend to perform some read/write operations on internal registers inside minion S10 DX kit ; from master kit.
I tired searching about s10DX kit capabilities and the best thing i found is https://www.intel.com/content/dam/altera-www/global/en_US/support/boards-kits/stratix10/dx_fpga/stra... this diagram. it shows open ended I2C via Max10 system Control. I am wondering if I can connect two S10DX through this route. is this doable?
Also; is there any user guide or design example guide you can point me to? on using I2C with S10 DX kit?
thanks
- Tags:
- i2c
- Intel® Stratix®
is there any I2C connector on the kit which i can use to connect with the other kit? also where can i purchase the cable to connect these two I2C ports over two s10DX kits? i will need 1 meter long cable if possible.
