Consulting on FPGA issues
DS14
Hi
The FPGA I was using was discontinued and the model was EPM7064AETC100-4,what models are available now for pin to pin
_AK6DN_
Valued Contributor II
None from Intel/Altera. No F/F/F pin compatible replacements.
Look at the Microchip/Atmel ATF1504ASV-A100; it is a production part that is a functional replacement.
Using the Microchip POF2JED program you can convert your Altera .pof design file to an Atmel .jed file for programming.
Speed grades are different tho, so absolute compatibility depends on your performance requirements.
NazrulNaim_Intel
As user 'AK6DN' have replied to this issue. The answer can be accepted as the answer for this request.
Hope that answers your question.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
