6125 Discussions
Core Power cost of C10LP 10CL040YU484C6G
TGao
Dear Sir/Madam
Could you help to check ​the Core power cost of 10CL040YU484C6G? I'm using the 1.2V /1.5A(max) power to supply it, not sure it's enough or not.
Ted.Gao
YuanLi_S_Intel
Hi Ted,
The core voltage, VCCINT can be 1.2V / 1.0V. As long as your supply voltage is meeting these requirement, it would be ok to use it.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51002.pdf
Thank You.
TGao
Hi SooY, Thanks for your reply. What I’m worried about is not Voltage, is Current. I’m not sure the 1.5A is enough or not. Do you have same evidence on handbook or papers about the current? Ted
YuanLi_S_Intel
Hi Ted,
I believe it should be ok. However, to check the total current drawn, you may use our estimator tool available at link below:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/operation-and-testing/power/c10-lp-power_estimator_download.html
Thank You
TGao
