5931 Discussions
Current Sink from GPIO 3.3 LVTTL
I've designed a circuit to generate step and directoin signals for external stepper motor drivers. The input current for these drviers is "-1 mA" which I believe means I need to sink 1mA of current. Is the FPGA capable of sinking this much current? I have read that it can output up to 24mA but how much can it sink? I did not find this information anywhere. If anyone can help me I would really appreciate it!
My board is a DE2-115 and the output pins are of the GPIO pins using 3.3 volt logic.
--- Quote Start ---
--- Quote End ---
Yes, the output characteristic of FPGA and CPLD I/Os is almost symmetrical. The sink capabilty will be even slightly higher than the source strength. Some numbers can e found in the DC characteristic part of the device data sheet, complete data for individual IO standards and current strength settings can be found in the ibis files.
Thank you very much.. I suppose my problem is somewhere else!
