6020 Discussions
Cyclone 10 LP nConfig problem
omriL
I have a project where I have connected the nConfig pin of the Cyclone 10 LP thru FET (drain pin) with PU.
the gate of the FET is connected to GPIO of bank 8 (3.3V), and the source connected to GND.
On power up the state of the GPIO is as desined in the FAB and it become high - so the FET is saturated and the nConfig pin is driven low.
this issue generate a loop where the FPGA can not finish the init proccess and I have to remove the serial resistor from the gate of the FET to let the FPGA finish the init proccess.
this connection was on my previous design with Cyclone 3 and it worked well.
Is there any reason why it is happaning?
Can I chnage the state of the GPIO before the init proccess finish? (there is a way to set GPIOs as weak Pull-Up but no weak Pull-Down)
thanks for the help
FvM
Valued Contributor III
the usual solution is to connect a pull-down overriding weak pull-up, value depending on FET Vth e.g. 470R to 1k.
omriL
Hi FvM,
Thanks for the  help,
will try and share the resualts,
BR,
Omri
Fakhrul
Hi OmriL,
FvM is correct. You can also set the I/O to weak pull-up during configuration.
Fakhrul
Fakhrul
As we do not receive any response from you to the previous notification that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
