hello everybody!!
I am working on a project using an Altera cycloneI EP1C6T144C8. I would like to know what type of flash memory is compatible for this FPGA. Thanks!!Link Copied
--- Quote Start --- hello everybody!! I am working on a project using an Altera cycloneI EP1C6T144C8. I would like to know what type of flash memory is compatible for this FPGA. Thanks!! --- Quote End --- That would be EPCS1 (with compression) or EPCS4, EPCS16, EPCS64, EPCS128. Also the use of compatible devices from Numonyx, Micron, ST or Atmel or is possible (and cheaper). Good luck, Ton
thank you Ton :)))
Topic Options
