I am using an Altera Cyclone III development board.
Into pin J4 which is suppose to be 2.5 volts - is it 3.3volt tolerant?Link Copied
I can only guess, which board and pin J4 you mean. Altera Cyclone III 3C120 Development Board? Signal HSMA_TX_D_P11 connected to FPGA pin J4?
All I/O pins are 3.3V tolerant, you should however keep the tolerated overshoot range for safe Cyclone III operation.- Mark as New
Yes, you can use 3.0V for security consideration instead of 3.3v, it may damage the cyc3.
You can have damaging overshoots at 3.0V too, it's better to ensure that the cyc3 pins are well protected against overshoots (clamping diodes, and/or a buffer close to FPGA as an example) rather than just reduce the I/O voltage by 0.3V.
