6363 Discussions
Cyclone IV GX Transceiver Nios MAC
I am using the Cyclone IV GX Transceiver Starter Board and Quartus 12.1.
The Qsys or SOPC tools seem straight forward on implementing the FPGA portion.
The Nios II EDS provides a starter template project for Simple Socket Server.
The Template description indicates the requirement for a lan91c111 Ethernet MAC.
I don't have this hardware on the kit.
I searched the examples provided with the kit but did not find any code/examples
for the NiosII portion.
Is there a simple poject for the Nios II EDS compatable with my kit that would serve as a starting point?
My target application is a data acquisition implementation that will initially forward data via UDP protocol.
Any help appreciated.
Fred:-)
I located the BoardTestSystem - BT_General project in the kit examples folder.
When I try to compile the Quartus project, I get the following warnings.
Warning (15709): Ignored I/O standard assignments to the following nodes
Warning (15710): Ignored I/O standard assignment to node "L0_led"
Warning (15710): Ignored I/O standard assignment to node "local_rstn_ext"
Warning (15710): Ignored I/O standard assignment to node "pcie_rstn"
Warning (15710): Ignored I/O standard assignment to node "refclk"
Warning (15710): Ignored I/O standard assignment to node "rx_in0"
Warning (15710): Ignored I/O standard assignment to node "rxp"
Warning (15710): Ignored I/O standard assignment to node "tx_out0"
Warning (15710): Ignored I/O standard assignment to node "txp"
I have located these identifiers in the Assignment Editor. Not sure why they are there.
Finally, I get the following Error.
Error (170012): Fitter requires 903 LABs to implement the project, but the device contains only 900 LABs
I am trying get to the point where I have a working example for the Simple Socket Server as a starting point.
Any guidance appreciated:-)
I reduced the original ram size in the example from 16384 to 10240.
program builds and loads. Successful run of Simple Socket server
from example.
