5892 Discussions
Cyclone V DevKit with HPS disabled, GPIO does not work
I am testing a custom cpu on SoC Devkit, since I don't need the presence of ARM HPS, I just
program directly the .sof file into the FPGA, and running in with the sdcard removed (I have another
project inside sdcard which is running GSRD on that sdcard).
Currently, I am testing a custom uart module and trying to print some letters from cpu through uart.
The tx pin is assigned to one of HSMC pinout (PIN G13), I use GPIO breakout board provided in the box,
In my other project, the gpio can output signal without problem, however, although I can see the signal
is outputting from tx on SignalTap, I can't observe any change on GPIO pin on my oscilloscope..
Is there any special configuration needed to run the Cyclone V FPGA without the HPS??
