6472 Discussions
Cyclone V Early Power Estimator not opening
seaharrier
I have downloaded the Early Power Estimator (EPE) for Cyclone V FPGA devices family from the Intel website, link: https://cdrdv2.intel.com/v1/dl/getContent/652737
The Excel file is showing corrupted, and whatever I do it is not opening.
Please help me open the excel file, or provide the latest stable version of the EPE.
sstrell
What version of Excel/Office are you using to open it?
NazrulNaim_Intel
Regarding your issue. Please follow the steps below :
Microsoft has released an update to fix this issue, please go to the corresponding Microsoft Support Page based on your Excel version:
·        Excel 2013*: https://support.microsoft.com/en-us/kb/2920754
If the above update doesn't fix the issue, or if you do not have access to these updates, try the following workaround steps:
1.   Reboot the computer if you've installed the above update.
2.   Close all Microsoft Office applications including the Excel* and Word* applications.
3.   Open a Windows* Explorer, and enter "%temp%" (without quotes) into the address bar.
4.   Press "Ctrl" + "F" and enter ".exd" (without quotes) into the search box.
5.   If any files with extension ".exd" are found, select and delete ALL the files that are found.
6.   Next, enter "%appdata%" (without quotes) into the address bar. Again, press "Ctrl" + "F" and search for ".exd", and delete ALL the files that are found.
7.   Reopen the EPE.
If the issues remain, follow these steps:
1.   Launch the EPE tool, go to File -> Info-> Compatibility Mode, and click Convert.
2.   If a pop-up appears, click OK to proceed with conversion, and then click Yes to reopen the workbook.
The previous steps convert the original ".xls" EPE file into a ".xlsm" file. The newly created file should not exhibit the original issue.
Microsoft's description for this issue can be found at:
https://support.microsoft.com/kb/2726958
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
