Hello all,
I have a Cyclone V GX starter kit (5CGXFC5C6F27C7N) board, and I am trying to program it using Ubuntu 14.04. I already compiled the code and it does not have any error. However, when I open the "programmer" application (tools->programmer), my device is not recognized. I clicked the "hardware setup" button and the only option I can choose is USB-Blaster variant 2-1. When I plug it using windows 7, it does not have any problem. So, I wonder if ubuntu 14.04 is not ready for this board :cry: Do you know what can I do to get my board recognized so I can program it?:confused: https://www.alteraforum.com/forum/attachment.php?attachmentid=9294 https://www.alteraforum.com/forum/attachment.php?attachmentid=9295 I would appreciate your help, and if you need further details, please let me know. Thanks in advance for the help on this.- Tags:
- Cyclone® V FPGAs
Did you setup the USB-Blaster device nodes correctly?
http://www.altera.com/download/drivers/dri-usb_b-lnx.html These are the RedHat/Centos instructions. Ubuntu is a little different, search the group and you'll find setup instructions. If you can't find them, I can look in my Ubuntu setup notes tomorrow. Basically you need to set the permissions on the USB-Blaster so that "regular" users can access the device. You can test whether or not this is the issue by plugging in the USB-Blaster and then as root manually change the device node permissions (via chmod 666). Cheers, Dave
