We purchased two Cyclone V SoCFPGA development kits, and tried to boot them using the microSD card which is shipped together with the kits. But we met bellow CRC issue (full log in attached screenshot):
SDRAM: ECC Enabled
ALTERA DWMMC: 0
Bad image with mismatched CRC
### ERROR ### Please RESET the board
We also tried the image from http://releases.rocketboards.org/release/2017.10/gsrd/bin/linux-socfpga-gsrd-17.1std-cv.tar.gz, but got the same issues.
The two boards have the same issue.
Please advice what's wrong with it, and how to fix?
Thank you.
-Austin
Welcome to INTEL forum. May I know Quartus version and Dev,kit serial number that you use?
For privacy you could use private message
Thanks. The image https://releases.rocketboards.org/release/2019.10/gsrd/cv_gsrd/ works
This page is misleading
https://rocketboards.org/foswiki/Documentation/GSRDBootLinuxSd
Thanks for pointing out the correct link. May I know, does this solve your issue?
Yes. The issue is solved.
Thanks for you update. I will close this case for now.
