6473 Discussions
CycloneVsoc GPIO multiple use question
CAlex
New Contributor II
Hi
I have some questions about the pin multiplexing of this SOC. On the HPS component, I can choose to use set0, set1 or set2 of the UART pins (taking UART0 as an example), but according to the CyclonVsoc design diagram, only set2 of the GPIO is connected to UART_TX and UART_RX, and because this is a hardware-connected circuit, it cannot be changed by Pin Planner. Does this mean that if I want to use UART0, I have to use set2?
picture 1: HPS interconnection
Thank you.
sstrell
That's a schematic for a particular board design (I'm assuming a dev kit) so yes you'd have to use whatever those pins are connected to.  Obviously, with your own board, you could choose whichever set of pins you wanted to use for the UART as long as you designed your board that way.
sstrell
EBERLAZARE_I_Intel
Yes, agree with @sstrell, just checking are you using the CV SoC Dev kit board?:
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/cyclone/v-sx.html
EBERLAZARE_I_Intel
Do you have any further questions?
CAlex
New Contributor II
Sorry for the late reply.
All the questions I have in this thread have been answered.
Thank you.
EBERLAZARE_I_Intel
If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
