5925 Discussions
DDI Port mapping to FPGA Pins
SB_S
For DDI port , should I need to use the transceiver pins(1C bank) or differential pins of 2L bank of 10AS016?
CheePin_C_Intel
Dear Supritha, As I understand it, you seems to have some inquiries related to the A10 DDI port. To ensure we are on the same page, would you mind to further elaborate on the following: 1. What is the specific A10 SX part that you are using? 2. Are you using a devkit from Intel PSG or your own board? 3. Would you mind to further elaborate on the DDI port that you are referring to? Is it some interface availabe on the devkit? Some web reference or explanation on this interface will be helpful. 4. Please share with me also the specific data rate and requirement for the DDI port. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
SB_S
Please see my answers as below -
1​. What is the specific A10 SX part that you are using?
SBS : Full Part number is 10AS016.
SBS : We are developing a new board with 10AS016.
SBS: Yes, this DDI port is available on the Dev Kit. DP_ML_LANE_N0 is the net name used in the Devkit.
SBS : if DDI port works at lower speed also is fine for us.
CheePin_C_Intel
Thanks for your clarification on the net name in the A10 SOC devkit. As I understand it, the DDI port that you are referring are for Display Port. Based on my understanding with Display Port usage in A10 devices, generally they are connected to the high speed XCVR pins instead of GPIOs.
Chee Pin
SB_S
SB_S
​And also instead of 4 lanes of DDI ( Display port ) , can we use just 2 DDI lanes to connect the Display and does the Display  Port IP supports the 2 lane implementation ?
CheePin_C_Intel
Hi, as I checked with the A10 DisplayPort IP, the "Maximum lane count" support value of 1, 2 and 4. Therefore, there should be no issue to support 2 lanes.
