Can the HSMC interfaces on the Stratix IV GX development board support 500 MHz (1000 GBPS) DDR LVDS?
--- Quote Start --- Can the HSMC interfaces on the Stratix IV GX development board support 500 MHz (1000 GBPS) DDR LVDS? --- Quote End --- I don't see why not. I have been using the transceivers at 5Gbps and higher. Assuming the LVDS layout is good, you should be fine. I've tested the Stratix II LVDS at 1Gbps. I would expect the Stratix IV to work fine. What are you interfacing to? Cheers, Dave
Dave,
Thanks for your reply. Yes, it's the LVDS routing of the Stratix IV GX development board that I'm concerned with. I would like to know if it is good enough for 1 Gbps. I'm interfacing to an Analog Devices AD9434 12-bit 500 MSPS ADC. It supports both SDR and DDR transmission. I'll use the SDR mode at first but would like to try the DDR mode, as well. http://www.analog.com/en/analog-to-digital-converters/ad-converters/ad9434/products/product.html AndyHi Andy,
--- Quote Start --- Yes, it's the LVDS routing of the Stratix IV GX development board that I'm concerned with. I would like to know if it is good enough for 1 Gbps. --- Quote End --- It should be. Do you have the board? If you don't, I could probably test the boards I have. But I wouldn't get a chance to until next week sometime. Unless of course you have a test design, that has a nice testbench, so that I can see the design, then I'll download it :) --- Quote Start --- I'm interfacing to an Analog Devices AD9434 12-bit 500 MSPS ADC. It supports both SDR and DDR transmission. I'll use the SDR mode at first but would like to try the DDR mode, as well. http://www.analog.com/en/analog-to-digital-converters/ad-converters/ad9434/products/product.html Andy --- Quote End --- Does your design provide a frame clock for the LVDS demux logic? Read these if you don't know what I'm talking about: http://www.ovro.caltech.edu/~dwh/carma_board/at84ad001b_tests.pdf http://www.ovro.caltech.edu/~dwh/carma_board/digitizer_tests.pdf Cheers, DaveFor more complete information about compiler optimizations, see our Optimization Notice.
