DDR SOPC PLL problem
Hi, I tried following the "SOPC builder flow" in chapter 2 of ug_ddr_ddr2_sdram_hp.pdf. But
  • When I hit "Generate" in SOPC, I get a popup error that says, "Can't find file my_project/altmemddr_0_phy_alt_mem_phy_pll.qpf".
  • I click "OK" on this popup and the "Quartus II MegaWizard Plug-In Manager" comes up with an error message in its System message tab that says "Error: unknown short option -s. Refer to --help for legal options."
  • I close this window by clicking on the X in the upper right corner and SOPC generation continues
  • I try compiling the example top level design in Quartus, but get an error message that says, 'Error: Node instance "pll" instantiates undefined entity "altmemddr_0_phy_alt_mem_phy_pll"
I'm using Quartus Linux web edition 9.1 beta. Thanks in advance for any advice on how to proceed.
Exact same problem here.
Using 9.1sp1 Linux beta.
Ever get any feedback on this?
I filed an SR on it (#10748663 if you want to bug your own rep.). They said it will be fixed in the next release and closed the SR.
