DDR4 校准不过
AMa
Partner
Hi
我们客户用了8片DDR4,分为两组,每组64bit。
布线前,分配IO检查过,fitter能跑过。
现在问题是,上电后,local_cal_fail拉高,校准不过。
我检查过时钟,给的100M 参考,与IP内对应,电源1.2V与0.6V的参考都是ok的。
上电后,IP的emif_usr_clk能正常出来,说明参考时钟正常进去了,然后时钟出来了?
我也试过降频测试,从1200M降到800M,但是都依然出现校准不过。
用toolkit测,8个group校准都fail了
NurAida_A_Intel
Good day to you. 😊
May I know which stage it is failing on the EMIF Toolkit? Is it a consistent group's failure or intermittent ?
At the meantime, you can go through the “Check list for troubleshooting calibration failure” that available in link below and see which item might be applicable in your case.
Calibration Checklist: https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/calibration-checklist.html
I also suggest you to generate DDR4 example design, with same device and all the memory setting and see if the calibration pass/fail. This will help to isolate further as below:
  • If it passed, then you know that issue is possibly related to board issue or any other build issue.
  • If it failed, then highly it’s DDR4 interface issue.
Let me know your feedback.
Aida
AMa
Partner
Hi, Aida
Thanks for your relpy, I had solved this issue. The reason is Alert_n connect to 1.2V.
NurAida_A_Intel
Glad to know everything is working fine at your side now. 😊
Feel free to post any question if you need help/support in future.
Thank you and have a nice day!
Aida
