5692 Discussions
DE0 connector locations in layout, daughter card development
There is great general information in the readily available university dev boards documents, but I would like to build a daughter card that mates to the DE0. It would be much easier to start with the part information and layout locations for the board stand-offs and connectors. Since these boards have been out for a long time, I am confident that information is available. I have not yet found it. Does anyone know where to find it, or who to ask for it?
Thanks - REM
We've made a little daughter card for the DE0 that we use to drive 50 ohm signal generators..
I'll see what I can dig it up. It's about a 2x2 board total. And could power the DE0 via a usb connector on the board if desired.
Ok. We had the following part number in the bom for the two 40 pin headers
SSM-120-L-DV-LC SSM-120-L-DV-LC Samtec
RECPT 2X20 .100" PITCH W/ LOCKING CLIPS
They are aligned vertically, and are space 800 mils apart horizontally, we had the deepest 42 mils from the back edge of the board. The board was 2200 mils wide and fit within the Plexiglas cutout on the DE0..
(With the connectors centered in the 2200 mils)
Pete
