5553 Discussions
DE1-SoC "my_first_HPS" tutorial
I want to use HPS on DE1-SoC board. I am following the instructions provided in the manual My First HPS. I downloaded and installed EDS under C:\altera\15.0 directory. When I type "Make"on the Embedded Command Shell, I get the error massage; 'Make' is not recognized as internal or external command ....... I searched for a Make.exe within C:\altera\15.0\embedded and there are several; I do not know which one to execute to compile my program, however I decided to execute this one:
C:\altera\15.0\embedded\ds-5\bin\Make
I get a error message - se attached screen shot.
Is this the right "Make" ?
How to define a path for the right Make?
My operating system is Windows 7
--- Quote Start ---
--- Quote End ---
Could you please check if you have set the SOCEDS_DEST_ROOT environment variable as C:\altera\15.0\embedded or not?
Barbara,
Thank you Barbara. Please tell me how do I check for the environment variable?
--- Quote Start ---
--- Quote End ---
Please right click My Computer[/B],[/B] and select properties, and then click Advanced System Settings[/B][/B] and Environment Variables[/B][/B], then you can click Edit [/B][/B]to set the SOCEDS_DEST_ROOT environment variable as C:\altera\15.0\embedded.
I attached the steps for your reference.
Barbara,
