I have installed device driver for Altera USB-Blaster. Windows 7 device manager is showing "Altera USB-Blaster" in USB devices but the device is not shown in Tools->Programmer. I have added the device (10M40DCF484) manually using Add Device option. But when I open the SignalTap II Logic Analyzer, I get "No device is selected" in JTAG Chain Configuration. Scan Chain option does not do any action (as seen in the scanned image).
Thank you very much for your help.- Tags:
- de10-lite
Click the Setup button to select the USB Blaster hardware.
Hi Zubair,
1. Have you turned on the hardware/ development Board?- You can add device in programmer without turning on the board.
- You can see USB blaster available in device manager without turning on the board by just connecting the USB blaster to the PC.
- But signal tap we can't add like that, it will automatically detect or by setup option.
Thanks sstrell and Anand for your replies. None of the suggested items worked. I have found the cause of this issue to be a conflict between Altera USB Blaster device driver and another USB to JTAG device driver from TI board that I am using to interface with the DE-10 Lite board. Apparently both use FTDI chip. Fortunately, the TI board I am using also supports a second JTAG interface via Blackhawk v2 System Trace debugger that does not conflict with the Altera device driver.
Zubair
