Can anybody help me locate a driver for windows for DE10-Nano? The CDC Serial is a bit of a mystery at the moment. When I look here (for example): https://software.intel.com/en-us/node/731117 It refers to a FTDI chip - the drivers do not install at all. So maybe CDC Serial is from some other manufacturer? Thanks, leftyLink Copied
Refer the link for installation and debug steps. http://www.ftdichip.com/support/documents/installguides/an_396%20ftdi%20drivers%20installation%20guide%20for%20windows%2010.pdf Let me know if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
I bumped into the same issue. For serial connection, you should use the mini-USB connector. That one instances into a USB-serial port correctly.
If you happen to plug into micro-USB, CDC serial would appear, but that won't instance into a serial port. So that's for LAN-over-USB route. Basically, beware of different USB connectors.- Mark as New
Thanks for that. Yes, it is an easy mistake to make!
