All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
5844 Discussions
DE10-Nano Handling FPGA interrupts
I'm trying to find info on how to handle an IRQ from FPGA to HPS via f2h_irq0 Interrupt Receiver.
For now I don't have a clue. I just found info on how to handle GPIO like KEY0 or KEY1 but they are mapped to the HPS region.
I hope to capture edge interrupts from SW[4..0]. Maybe I can find somebody with experience with this here.
Regards!
--- Quote Start ---
Regards!
--- Quote End ---
Hello.
For baremetal application use hardware libs routines for interrupt control and ISR handler registration.
Hey thanks !
I'm trying to catch interrupts under linux. I was reading the altera documentation for HWLIB and SoCAL APIs without success.
This is a simple starting program with a strange error:
#include <stdio.h> # include "hwlib.h" # include "alt_interrupt.h" int main() { ALT_STATUS_CODE status; status = alt_int_global_init(); if(status == ALT_E_SUCCESS) printf("exito..."); return 0; }
I got this error:
$ make build arm-linux-gnueabihf-gcc -g -Wall -Werror -ID:/intelFPGA/17.0/embedded/ip/altera/ hps/altera_hps/hwlib/include -ID:/intelFPGA/17.0/embedded/ip/altera/hps/altera_h ps/hwlib/include/soc_cv_av -Dsoc_cv_av -c main.c -o main.o arm-linux-gnueabihf-gcc -g -Wall -Werror main.o -o ledtest main.o: In function `main': C:\Users\nhasbun\Desktop\C/main.c:7: undefined reference to `alt_int_global_init ' collect2.exe: error: ld returned 1 exit status make: *** Error 1
And I'm using this makefile (https://pastebin.com/zxwzybqf) that I got from Altera examples for this board. Not sure what the problem is, since the header is being read.
It's very simple from a hardware standpoint. f2h_irq0 is a 32-bit input. Connect SW[4:0] to f2h_irq0[4:0] (or whichever 5 bits you want to use) and tie the remaining f2h_irq0 bits to logic 0 if you're not using them for other interrupt sources.
Hey thanks!
I should stated that I was working under linux!. I was reading the altera documentation for HWLIB and SoCAL APIs without success.
I got this error:
I guess it's a linker problem on my makefile ?
Ok, so I solved that error by copying the alt_interrupt.c file to folder and improving a little my makefile.
But now I got this error:
C:\Users\nhasbun\AppData\Local\Temp\ccJaPb6S.s: Assembler messages: C:\Users\nhasbun\AppData\Local\Temp\ccJaPb6S.s:91: Error: Thumb encoding does no t support an immediate here -- `msr CPSR_c,#(0x12|0x80|0x40)' make: *** Error 1
This is my makefile:
--- Quote Start ---
TARGET = main
ALT_DEVICE_FAMILY ?= soc_cv_av
HWLIBS_ROOT = $(SOCEDS_DEST_ROOT)/ip/altera/hps/altera_hps/hwlib
SRCS=$(wildcard *.c) $(wildcard */*.c)
OBJECTS=$(SRCS:.c=.o)
CFLAGS = -g -Wall -Werror
-I$(HWLIBS_ROOT)/include
-I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY)
-D$(ALT_DEVICE_FAMILY)
LDFLAGS = -g -Wall -Werror
-pthread -lpthread -lm
CROSS_COMPILE = arm-linux-gnueabihf-
CC = $(CROSS_COMPILE)gcc
LD = $(CROSS_COMPILE)gcc
ARCH = arm
.PHONY: build
build: $(TARGET)
$(TARGET): $(OBJECTS)
$(LD) $(LDFLAGS) $^ -o $@
%.o : %.c $(HEADERS)
$(CC) $(CFLAGS) -c $< -o $@
.PHONY: clean
clean:
rm -f $(TARGET) *.a *.o *~
rm -f $(UART_CORE_LIB_ROOT)/*.o
--- Quote End ---
Hi!
Are you solve the problem now? I happend to have the same problem, I copy the alt_interrupt.c file to my project folder and add command lines to my nmake, but it still dosen't work.The error like
Thumb encoding does not support an immediate here -- `msr CPSR_c,#(0x12|0x80|0x40)'
I just gave up. It seems like we had the libraries to use the FPGA interrupts under Linux but there is simply not enough info out there on how to make it work.
