Hi, I have just started the DE10-Standard kit and run-thru the tutorials included in the package. I was stucked in the My_First_HPS section and got the error below:
"make: *** no rule to make target '/intelfpga/16.1/embedded/ip/altera/hps/altera_hps/hwlib/include/', needed by '-ic'. stop."https://alteraforum.com/forum/attachment.php?attachmentid=13930&stc=1 Below is my makefile: # target=my_first_hps alt_device_family?=soc_cv_av soceds_root?=$(soceds_dest_root) hwlibs_root=$(soceds_root)/ip/altera/hps/altera_hps/hwlib cross_compile=arm-linux-gnueabihf- cflags=-g-wall -d$(alt_device_family) -i$(hwlibs_root)/include/$(alt_devive_family) -i$(hwlibs_root)/include/ldflags= -g-wall cc=$(cross_compile)gcc arch=arm build: $(target) $(target):main.o $(cc)$(ldflags) $^-o$@ %.o:%.c $(cc)$(cflags)-c[I] $(CC)$(CFLAGS)-c$<-o$@[/I]lt;-o$@ .phony:clean clean: rm-f $(target)*.a*.o*~
Below is my folder structure: C:\intelFPGA\16.1\embedded C:\intelFPGA\16.1\embedded\Embedded_Command_Shell.bat C:\intelFPGA\16.1\embedded\Embedded_Command_Shell.sh C:\intelFPGA\16.1\embedded C:\intelFPGA\16.1\embedded\drivers C:\intelFPGA\16.1\embedded\ds-5 C:\intelFPGA\16.1\embedded\ds-5_installer C:\intelFPGA\16.1\embedded\embeddedsw C:\intelFPGA\16.1\embedded\examples C:\intelFPGA\16.1\embedded\host_tools C:\intelFPGA\16.1\embedded\ip C:\intelFPGA\16.1\embedded\my_first_hps C:\intelFPGA\16.1\embedded\my_first_hps\main.c C:\intelFPGA\16.1\embedded\my_first_hps\makefile Rgds, Joven
This is my makefile for a "hello world" example coming with the de10 nano board.
TARGET = my_first_hps
ALT_DEVICE_FAMILY ?= soc_cv_av
HWLIBS_ROOT = $(SOCEDS_DEST_ROOT)/ip/altera/hps/altera_hps/hwlib
CFLAGS = -g -Wall -Werror -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
LDFLAGS = -g -Wall -Werror
CROSS_COMPILE = arm-linux-gnueabihf-
CC = $(CROSS_COMPILE)gcc
LD = $(CROSS_COMPILE)gcc
ARCH = arm
.PHONY: build
build: $(TARGET)
$(TARGET): main.o
$(LD) $(LDFLAGS) $^ -o $@
%.o : %.c
$(CC) $(CFLAGS) -c $< -o $@
.PHONY: clean
clean:
rm -f $(TARGET) *.a *.o *~
Not sure what is the problem with yours but I would add: .PHONY: build and execute make build
Hi nhasbun,Thanks a lot, it works. Now my next issue is it did not show the "inet addr". i tried few suggestions (eth0 down/up, restart) from other forum but it didn't work.
Not sure what do you mean by that.
Are you starting linux and try to connect to a LAN ? If it is a program try to paste your C code.- Mark as New
Yes,im starting up linux via putty terminal. I login successfully using root and type "udhcpc" then "ifconfig". the result don't show the "inet addr" in eth0.
hi, i managed to make the LAN work by manually configuring the ipaddress of eth0. although it keeps resetted everytime i restart the kit but it's ok for the moment. tnx!
