5775 Discussions
DE1SOC Running HPS Control LED example
Hello:
I have been trying to run the HPS Control LED and HEX program but given the MSEL setting of 01010 or 01110 both turn up to hang at boot stage as the altera_load : Failed with error code -4. The only MSEL where it works is 00000, but the documentation calls for not using that setting.
Why is uboot failing to load this image. I have the standard linaro ubuntu image from the website.
If anyone has successfully run this, or managed to load their own rbf on this system, would you please point me in the correct direction.
gate_keeper
