Hi everyone,
i am trying to erase the Flash memory on my DE2-115 Board, so i can push a new file to it. The problem is, it says: "Erase failed at offset 0". Maybe the table is corrupt?$ nios2-flash-programmer --base=0xd0800000 --debug --erase-all
Using cable "USB-Blaster ", device 1, instance 0x00
Resetting and pausing target processor: OK
Found CFI table in 8 bit mode
Raw CFI query table read from device:
0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
20: 51 51 52 52 59 59 02 02 00 00 40 40 00 00 00 00 QQRRYY....@@....
30: 00 00 00 00 00 00 27 27 36 36 00 00 00 00 07 07 ......''66......
40: 07 07 0A 0A 00 00 03 03 05 05 04 04 00 00 17 17 ................
10: 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 07 QRY..@.....'6...
20: 07 0A 00 03 05 04 00 17 02 00 05 00 02 07 00 20 ...............
30: 00 7E 00 00 01 00 00 00 00 00 00 00 00 00 00 00 .~..............
CFI extended table read from device:
0: 50 52 49 31 33 10 02 01 00 08 00 00 02 B5 C5 02 PRI13...........
10: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Read autoselect code 01-7E (in 8 bit mode)
No CFI override data for
Device size is 8MByte
Erase regions are:
offset 0: 8 x 8K
offset 10000: 127 x 64K
Device supports AMD style programming algorithm
Multi-byte programming with 32 byte buffer
Sector erase timeout is 16s
Word program timeout is 1ms
Buffer program timeout is 4ms
: Checksumming existing contents
00000000 : Needs erasing
00002000 : Needs erasing
00004000 : Needs erasing
00006000 : Needs erasing
00008000 : Needs erasing
0000A000 : Needs erasing
0000C000 : Needs erasing
0000E000 : Needs erasing
00010000 : Needs erasing
00020000 : Needs erasing
00030000 : Needs erasing
00040000 : Needs erasing
00050000 : Needs erasing
00060000 : Needs erasing
00070000 : Needs erasing
00080000 : Needs erasing
00090000 : Needs erasing
000A0000 : Needs erasing
000B0000 : Needs erasing
000C0000 : Needs erasing
000D0000 : Needs erasing
000E0000 : Needs erasing
000F0000 : Needs erasing
00100000 : Needs erasing
00110000 : Needs erasing
00120000 : Needs erasing
00130000 : Needs erasing
00140000 : Needs erasing
00150000 : Needs erasing
00160000 : Needs erasing
00170000 : Needs erasing
00180000 : Needs erasing
00190000 : Needs erasing
001A0000 : Needs erasing
001B0000 : Needs erasing
001C0000 : Needs erasing
001D0000 : Needs erasing
001E0000 : Needs erasing
001F0000 : Needs erasing
00200000 : Needs erasing
00210000 : Needs erasing
00220000 : Needs erasing
00230000 : Needs erasing
00240000 : Needs erasing
00250000 : Needs erasing
00260000 : Needs erasing
00270000 : Needs erasing
00280000 : Needs erasing
00290000 : Needs erasing
002A0000 : Needs erasing
002B0000 : Needs erasing
002C0000 : Needs erasing
002D0000 : Needs erasing
002E0000 : Needs erasing
002F0000 : Needs erasing
00300000 : Needs erasing
00310000 : Needs erasing
00320000 : Needs erasing
00330000 : Needs erasing
00340000 : Needs erasing
00350000 : Needs erasing
00360000 : Needs erasing
00370000 : Needs erasing
00380000 : Needs erasing
00390000 : Needs erasing
003A0000 : Needs erasing
003B0000 : Already erased
003C0000 : Already erased
003D0000 : Already erased
003E0000 : Already erased
003F0000 : Already erased
00400000 : Already erased
00410000 : Already erased
00420000 : Already erased
00430000 : Already erased
00440000 : Already erased
00450000 : Already erased
00460000 : Already erased
00470000 : Already erased
00480000 : Already erased
00490000 : Already erased
004A0000 : Already erased
004B0000 : Already erased
004C0000 : Already erased
004D0000 : Already erased
004E0000 : Already erased
004F0000 : Already erased
00500000 : Already erased
00510000 : Already erased
00520000 : Already erased
00530000 : Already erased
00540000 : Already erased
00550000 : Already erased
00560000 : Already erased
00570000 : Already erased
00580000 : Already erased
00590000 : Already erased
005A0000 : Already erased
005B0000 : Already erased
005C0000 : Already erased
005D0000 : Already erased
005E0000 : Already erased
005F0000 : Already erased
00600000 : Already erased
00610000 : Already erased
00620000 : Already erased
00630000 : Already erased
00640000 : Already erased
00650000 : Already erased
00660000 : Already erased
00670000 : Already erased
00680000 : Already erased
00690000 : Already erased
006A0000 : Already erased
006B0000 : Already erased
006C0000 : Already erased
006D0000 : Already erased
006E0000 : Already erased
006F0000 : Already erased
00700000 : Already erased
00710000 : Already erased
00720000 : Already erased
00730000 : Already erased
00740000 : Already erased
00750000 : Already erased
00760000 : Already erased
00770000 : Already erased
00780000 : Already erased
00790000 : Already erased
007A0000 : Already erased
007B0000 : Already erased
007C0000 : Already erased
007D0000 : Already erased
007E0000 : Already erased
007F0000 : Needs erasing
Checksums took 2.2s
00000000 ( 0%): Erasing
Leaving target processor paused
Has anybody a hint for me? With best regards, Jan
- Tags:
- de2-115
Topic Options
