DE2-115 Multiplexed SRAM
Using TerASIC SRAM component (tested and verified) and wanted to add a second Avalon MM slave. Created a second component with a MM master and a signal to control the mux selection. SRAM component is attached to NIOS CPU with address_master and data_master and attached to my component via SOPC builder. Mux control seems to work. When I select CPU, i can read and write SRAM from the CPU. However, when I try to access via my component, I get all 0xFF.
Basic design of my components memory master is this (all I want to do is read the SRAM. It is inside an always loop based on system clock:
state 0:
chip_select_n <= 0;
write_n <= 1;
address <= {12'b0,address_to_read);
read_n <= 0;
lbe_n <= 0;
hbe_n <= 0;
go to state 1
state 1:
go to state 2
state 2:
my_data <= readdata;
chip_select_n <= 01;
write_n <= 1;
address <= 32'bz
read_n <= 1;
lbe_n <= 1;
hbe_n <= 1;
Any thoughts on why I shouldn't be able to read on the non-CPU side of the MUX? Is my configuration valid given the Avalon MM paradigm.
Thanks, in advance,
ME
