5696 Discussions
DE2-115 complete beginners question
Hi
I am completely new to FPGAs but I am lucky enough to have been given a DE2-115
I know its a big learning curve but being retired I have plenty of time , but I cant even get started to try it out because
unfortunately the box is missing the system disk so I went online to see what I can download for the board.
I downloaded the user manual but was then stuck
I can download the
Control panel
System Builder
System CD
but which one , on line I can find lots of versions especially of the system CD
Eventualy on the Altera products, DE2-115 product page I clicked the resources tab and that gave me a narrower field to choose from
just one Control Panel
One Systembuilder
but still to System CDs
one is
DE2-115 CD-ROM (Cypress USB) of which there are then 4 versions
the other
DE2-115 CD-ROM (NXP USB)
Which one do I need ? or do I need both ?
Don
This is the official Terasic resource web page:
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=165&no=502&partno=4
You need the appropriate CD-ROM according to which USB device your board has. The manual should help you find this.
I think you have to download from the Altera website:
1) Quartus (web editon) free
2) Modelsim Altera Starter edition (free)
3) In the installation directory of Quartus youll' find the 'USB blaster' drivers.
This is all you need to design a circuit and download it on the FPGA board.
P.S. You also need the knoledge of a language such as VHDL or Verilog. This is not a must since you can also design using the schematic design (similar to Spice) but it becomes immediately very cumbersome as the design complexity increases.
Hi Thank you for your reply , however its a bit of a vicious circle
you said to choose the CD rom according to which usb device my board has , and to determine this device from the user manual
Unfortunately the manual is on the CD rom . so depending on which CD I decide to download I guess will give me a different answer as to which USB I have
I have now written to Terasic support quoting the serial number of my board hoping they can give me an answer from that
but thanks for the help
Don
--- Quote Start ---
--- Quote End ---
Thanks nplttr
I will start downloading and installing them now
Don
I wrote to Terasic in the end
They tell me that my board ( from the serial number ) uses the NXP USB but that this will not work with windows 7 only XP
They also said that the Cypress USB only works on windows 7 in 32 bit not 64 bit
Don
--- Quote Start ---
--- Quote End ---
I think you can ignore the advice about functionality under Windows for the moment. The board has a USB device attached to the FPGA that you can use for communication with your design. I've never bothered to use it.
The board also has an on-board USB-Blaster, and that does work under Windows just fine.
If Terasic has changed the USB controller, then they've likely changed the pin assignments on the board, but probably only in a few places. You'll want to make sure you download the schematic for the board revision you own, and determine the pin assignments from that. Do *not* simply use an example design you find on the web! (Including any from Terasic, without first reviewing it!)
Cheers.
Dave
Thanks Dave
Yes I found that the USB Blaster works fine and I doubt I will need any other usb connectivity for some time , as I
have only been playing with FPGA's for about 8 hours ( got my DE2-115 yesterday)
