Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
DE2 Demonstration Project
Hi~
I bought a DE2 Board to study NIOS II.
When I compiled some demonstration projects, I had following warning.
"Info: SRAM Object File C:/z.temp/DE2_System_v1.6/DE2_System_v1.6/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW/DE2_NIOS_DEVICE_LED_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2"
So I can't make pof file.
How can I solve problem?
Another sample project including NIOS II works fine.
TIA,
--- Quote Start ---
Hi~
TIA,
--- Quote End ---
your design contains a Megafunction which is not fully support by your Quartus license.
I assume that you use the Web Edition of the Altera tools. You can solve the problem only by upgrading your tools to the full versions.
Kind regards
GPK
