DE2 Programming Problems
Folks,
I've been struggling with a DE2 Board. The board's self-test works fine and I can push simple designs (all that I've tried) through Quartus II. However, I've never been able to program the board. I've updated my Quartus II to 7.1 and my USB-Blaster Driver to 2.0.0.0.
When I try to program the board in JTAG mode I get --
Info: Started Full Compilation at Thu Jul 12 14:03:28 2007 Eastern Standard Time
Info: Ended Full Compilation at Thu Jul 12 14:04:42 2007 Eastern Standard Time
Info: Started Programmer operation at Thu Jul 12 14:21:30 2007
Error: Can't access JTAG chain
Error: Operation failed
Info: Ended Programmer operation at Thu Jul 12 14:21:30 2007
When I try to use Active Serial Programming I get --
Info: Started Programmer operation at Thu Jul 12 14:23:06 2007
Error: Can't recognize silicon ID for device 1
Info: Ended Programmer operation at Thu Jul 12 14:23:06 2007
Does anyone have any suggestions? Did I get a bad board or am I doing something wrong?
Simon Read
Make sure you select the USB-Blaster in the programmer (Hardware Setup button in top left of the programmer screen).
Also, leaving programs like the DE2 Control Panel connected to the board will prevent you from programming.
It turns out that the issue was "User Brain Dead".
I had left the board turned off (little red button up). Somehow the idea of it being programmed during self-test threw me.
Thanks to everyone (including a patient Altera AE) for their help.
Simon
