I am producing PWM pulse using DE2 (cyclone || , EP2C35F672C6)
I want to know like how i should interface DE2 board with oscilloscope Thanks in advanceLink Copied
--- Quote Start --- I am producing PWM pulse using DE2 (cyclone || , EP2C35F672C6) I want to know like how i should interface DE2 board with oscilloscope Thanks in advance --- Quote End --- Hello, Do you want to interface the DE2 with the scope to look at your PWM pulse? If yes, then one way is to send your PWM pulse to one of the GPIO outputs and probe that output with your scope. Of course you need to be careful about having a common ground connection, output impedance etc. FYI for my DE1 designs, I either use SignalTap or an external logic analyzer via the GPIO pins. Hope that helps. Good luck. Bart
Topic Options
