Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
DE4 Simple Server Socket example
I have an Altera DE4 Development and Education Board. I’m using Quartus II 11.0.
I’m trying to run “Simple Socket Server (RGMII)” example.
This is the ‘Nios II Console’ output:
=============== Software License Reminder ================
This software project uses an unlicensed version of the NicheStack TCP/IP
Network Stack - Nios II Edition. If you want to ship resulting object
code in your product, you must purchase a license for this software from
Altera. For information go to: "http://www.altera.com/nichestack
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:ff:ed:15
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x05101800
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : Extended PHY Specific Status Register = 0x0001
INFO : PCS[0.0] - Configuring PCS operating mode
INFO : PCS[0.0] - PCS SGMII mode enabled
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.1.234
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
prep_tse_mac 0
Can't read the MAC address from your board (this probably means
that your flash was erased). We will assign you a MAC address and
static network settings
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
123456789
123456789
Your Ethernet MAC address is ff:ff:ff:ff:ff:ff
[tse_mac_init]
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO : PHY[0.0] - Link not yet established, restart auto-negotiation...
OK, x=89, CMD_CONFIG=0x00000000
mctest init called
IP address of et1 : 0.0.0.0
After this message, I try to connect via telnet to the board, but nothing happens.
Can you help me, please?
BR,
Umberto
It seems your flash memory stored invalid ip and mac addresses.
In your SSS project you should have a function named get_ip_add().
Try forcing *use_dhcp = 0 and momentarily set a well known static ip address.
In the same file you should also find a get_mac_addr() function: force it returning a fixed mac address, not ff ff ff ff ff ff
If everything works this way, debug into these functions in order to discover why you can't retrieve the correct addresses from flash.
Hi Cris72,
thank you for your support.
I already tried to do what you suggested me, but without success.
I also tried to do a restore of the flash with the factory settings, but I have not succeeded.
Forgive me if these are stupid questions, but I don't know your expertise level with network and embedded systems:
- are your sure the DE4 board is actually initializing with valid mac/ip addresses, as I said above?
- did you try a simple ping before testing the telnet connection?
- did you check your pc network configuration? did you configure the same subnet?
Hi Cris,
- I'm not surethe DE4 is initialized with valid mac/ip addresses. In this regard, I tried to do a reset to factory settings but I did not succeed.
- Yes, I tried pinging, but without success.
- Yes, I modified the file simple_socket_server.h to assign static network parameters.
BR,
Umberto
