6264 Discussions
DK-DEV-AGM039FES: Memory Preset custom file is not available for HBM2e
yas38
I downloaded the installer package agilex_agmf039r47a1e2vr0_v23.4b79_v1.0.zip for DK-DEV-AGM039FES and looking at the example design bts_hbm2e_bottom_hydra30_seed28.
I found an instruction in the note file (agilex_agmf039r47a1e2vr0_v23.4b79_v1.0/examples/Notes.txt). That is:
1. For bts_hbm2e_bottom_hydra30_seed28 and bts_hbm2e_top_hydra30_seed28, before compile, please open ed_synth.qsys then click 'ed_synth_hbm_fp_0' ip, then click the 'Parameters' -> 'Memory Device Preset Selection' -> 'Memory Preset custom file path for FSP0' to change the qprs file path to your local path.
However,
1) I could not find 'Memory Device Preset Selection' settings in the ed_synth_hbm_fp_0 IP. (see attached figure)
also,
2) I could not find any qprs file in the bts_hbm2e_bottom_hydra30_seed28 directory.
Any ideas to set the custom file?
I succeeded in compiling the example design. So, probably, the setting may not be needed.
Thank you,
AdzimZM_Intel
There is no memory preset setting for HBM2e IP.
You may ignore those notes.
Currently the memory preset setting is available for DDR4, DDR5 and LPDDR5 for Agilex M devices.
Adzim
AdzimZM_Intel
Adzim
yas38
Hi Adzim,
That is good to know. I could safely ignore the note.
Thank you!
