6367 Discussions
Default status on IO pins after program.
kwkprd
Recently i have worked on probing the FMC in scope and seen a sine wave immediately after programming the FPGA sof having the prbs generator. i want to know the status of FPGA IO's after programing.  In qsf file it is mentioned as HSSI IO standard pin mapping.
FvM
after programming, respectively in user mode, IOs are controlled by your design. All assigned IO pins take the state you have defined. Unassigned pins  get a default state (e.g. tristated with weak-pullup) specified in Quartus Assignments/Device/Device and Pin Options/Unused Pins.
NazrulNaim_Intel
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
NazrulNaim_Intel
As per user 'FvM' stated in the previous comment. The answer can be accepted, IO's are controlled by your design. All assigned IO pins take the state you have defined.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
