Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Designing a development baord
Hi All,
I would like to design a simple development board with Altera's Cyclone III chip. I have gone through extensive documentation available on Altera's website explaining schematic, layout etc etc of their kits. What I am unsure of is how to communicate with the computer and download data and configuration files to the FPGA? I would like to use the USB to do this, but not sure how to go about it..
Any pointers as to where to start would be useful..
Krish
The USB Blaster is the way to go for simplicity, just add the 10 pin header for active serial configuration and the correctly sized EPCS device for your Cyclone III. Make sure you have the 10 pin header for JTAG as well, with these two headers you can validate the Cyclone III directly, then program the bitfile in the EPCS for power on configuration. Both of these headers are documented in the configuration schemes in the Device Handbook. Look for AS or Active Serial configuration.
If you have a Microcontroller or CPU that has flash and memory, you can have it configure the Cyclone III though several methods, I prefer pasive serial mode in this case.
Then it could be possible, if the CPU supported USB directly you program though that interface, but it's really a limitation of the CPU you use.
Many of the new development boards from Altera basically have a USB blaster built into the board. This is nice, since it doesn't require a separate USB blaster, but you need a MAX II device and the code from altera to support it. I haven't gone this route yet, so I don't know if the USB Blaster CPLD code is readily available or not.
Pete
