Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Dev Board and IP recomendation..Pls Help.
I have this project where i have to take and process several (more than 5) images and store their information in a non-volatile memory in the development board and the then use the information to do some processing using NIOS inside the same board.... also i have to communicate with PC using serial communication to send and receive data.
Please recommend me a development board with:
1) High speed NIOS processor
2) Has onboard non-volatile memory like flash and etc...etc
3) can communicate with PC
also can anyone recommend me any IP to do some image processing and thing related to this work???
any suggestion are welcomed...Thank You...
