5931 Discussions
Device tree and HPS access
XChoo
Hello support.
I need to know if the device tree attribute disabled or ok affecting HPS access to FPGA peripherals .
Fawaz_Al-Jubori
The "Disable" and "OK" attributes in the device tree will disable or enable the driver of this peripheral. However, ARM can access the registers of these peripherals. You can use direct access via virtual memory to do this task.
Please let me know if you need further help.
Thank you
Fawaz_Al-Jubori
Thank you
XChoo
Thank you Fjumaah,
Your description was clear and help me to undestand the driver relation with disable or OK.
