5694 Discussions
Directives define in Nios II development compiler settings
In Nios II development tool, where to define compiler directives, such as # define DHCP_SERVER
thank you,
OnePlusOne
Which Version do you use?
NIOS 10.0 EDS: you can set it under properties->nios ii application properties
There is a field called defined symbols
Put there "-d<symbol to define>" for example "-ddhcp_server".
NIOS IDE 8.1:
Go to properties->c/c++ build and then choose the tab tool settings. Select Preprocessor and add your define under defined symbols
Philipp
Philipp,
Thank you.
Ok
I will try to give you an advice
