5931 Discussions
Does MAX10 FPGA supports Active/Passive Serial/Parallel configuration modes?
HUl_H
I want to program my MAX10 FPGA using another master FPGA or microcontroller. Does Max10 supports this configuration scheme?
a_x_h_75
New Contributor III
MAX10 only supports internal configuration (from built in FLASH) and JTAG.
See: https://www.intel.com/content/www/us/en/programmable/documentation/sss1393988509894.html
Cheers,
Alex
NurAiman_M_Intel
Thank you for contacting Intel community.
You can use the PFL IP core in Intel MAX® devices (Intel MAX 10, MAX II, and MAX V devices) or all other FPGAs to program flash memory devices efficiently through the JTAG interface and to control configuration from the flash memory device to the Intel FPGA.
Kindly refer to PFL IP userguide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Thank you.
Aiman
