Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Does the DDR use as lcd memory and program memoryat the same time?
I want use the ddr in My neek Board as lcd display memory and program memory at the same time, can I do it successfully?
And where or which component should I add in the system?
Highlighted
Yes it does. I had done this test before. It's works fine. Please refer to this link.http://www.altera.com/literature/hb/nios2/qts_qii55006.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=video sync
