Error(16614): OCT Block "emifchk_inst|emif_0|emif_0|arch|arch_inst|oct_inst|cal_oct.powerup_oct_cal.termination_inst" cannot terminate pins "O_FPGA_MEM1_A(0)~pad" and "IO_FPGA_MEM1_DQ(0)~pad" because they have different series termination values: "40 Ohms" and "34 Ohms" respectively. Change your pin assignments so that only pins with the same series termination value are connected to an OCT block.
Can anyone give solution for above error..
HI,
May I know you are using which Intel FPGA product family ?
The solution actually already lie inside the error message itself.
- The error pop up due to you are using 2 different termination setting 34ohm and 40ohm while Quartus expect user to use only one termination setting
Pls edit your IO pin assignment setting to use only one termination setting then the error should be gone
dlim
HI,
I didn't hear back further from you.
I hope my previous explanation on the issue solution is clear to you.
For now, I am setting this case to closure.
dlim
