Hi all
i'm working on EMIF for stratix 10 Dev KIT while generating the IP i can't find my board listed in the presets how can i add it ? if i can't what should i do ? ThanksLink Copied
Which Quartus Version & Edition are you using? Check the availability of supported devices & then download it, https://www.altera.com/downloads/download-center.html Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)- Mark as New
i'm using quartus pro 17.1
and i'm facing problem generating a working EMIF example design is there a portable preset that i can use ?- Mark as New
--- Quote Start --- while generating the IP i can't find my board listed in the presets --- Quote End --- Currently it is not available, In future it might get available. --- Quote Start --- if i can't what should i do ? --- Quote End --- You can download Golden Top Design, extract it & open .qpf file from your Quartus tool: (es edition, 17.1 (https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/stratix10/fpga/stratix10gx_1sg280uf50_fpga_revd_v17.1ib240_v1.0a.zip)) https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-s10-fpga.html Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)- Mark as New
Hi ,
i have already downloaded the package and tried generating several example designs and i always get calibration failed and i can't "create memory interface connection" in the EMIF Toolkit , so i can't even debug my design i already posted my problem about "create memory interface connection" you can find it in this link : https://www.alteraforum.com/forum/showthread.php?t=59053 and could you please provide me with a full datasheet of the daughter cards that came with the board : -ALTERA DRAM X72 DAUGHTER CARD -ALTERA RLDRAM3 X36 DAUTHER CARD -ALTERA EMIF HILO i have also tested the examples in the package after downloading the bit stream , in the ISSP i have calibration fail and i tried to run Board Test System (bts) but the gui can't detect the jtag cable so i'm facing so many problems , i don't have much time and i need help thanks- Mark as New
--- Quote Start --- i have already downloaded the package and tried generating several example designs and i always get calibration failed and i can't "create memory interface connection" in the EMIF Toolkit , so i can't even debug my design --- Quote End --- Refer the User guide, https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-20120.pdf For Daughter cards refer the following link, https://www.altera.com/products/boards_and_kits/daughter-cards.html --- Quote Start --- i have also tested the examples in the package after downloading the bit stream , in the ISSP i have calibration fail and i tried to run Board Test System (bts) but the gui can't detect the jtag cable --- Quote End --- Have you installed the drivers, if not, Refer following link & install before using it, https://www.altera.com/support/support-resources/download/drivers/dri-index.html https://www.youtube.com/watch?v=wjwkdznh1py Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)- Mark as New
Hi ,
--- Quote Start --- For Daughter cards refer the following link, https://www.altera.com/products/boards_and_kits/daughter-cards.html --- Quote End --- there are no memory daughter cards for stratix 10 --- Quote Start --- Have you installed the drivers, if not, Refer following link & install before using it, https://www.altera.com/support/support-resources/download/drivers/dri-index.html https://www.youtube.com/watch?v=wjwkdznh1py --- Quote End --- and i already installed the driver and it is working correctly , i'm using it to download the bit stream so same problems thanks
Topic Options
