5931 Discussions
EMIF on Stratix 10 Dev Kit miss board file
Hi all
i'm working on EMIF for stratix 10 Dev KIT
while generating the IP i can't find my board listed in the presets
how can i add it ?
if i can't what should i do ?
Which Quartus Version & Edition are you using?
Check the availability of supported devices & then download it,
https://www.altera.com/downloads/download-center.html
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
i'm using quartus pro 17.1
and i'm facing problem generating a working EMIF example design
is there a portable preset that i can use ?
--- Quote Start ---
--- Quote End ---
Currently it is not available, In future it might get available.
--- Quote Start ---
--- Quote End ---
You can download Golden Top Design, extract it & open .qpf file from your Quartus tool: (es edition, 17.1 (https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/stratix10/fpga/stratix10gx_1sg280uf50_fpga_revd_v17.1ib240_v1.0a.zip))
https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-s10-fpga.html
Best Regards
Vikas Jathar
Hi ,
i have already downloaded the package and tried generating several example designs and i always get calibration failed and i can't "create memory interface connection" in the EMIF Toolkit , so i can't even debug my design
i already posted my problem about "create memory interface connection" you can find it in this link :
https://www.alteraforum.com/forum/showthread.php?t=59053
and could you please provide me with a full datasheet of the daughter cards that came with the board :
-ALTERA DRAM X72 DAUGHTER CARD
-ALTERA RLDRAM3 X36 DAUTHER CARD
-ALTERA EMIF HILO
i have also tested the examples in the package after downloading the bit stream , in the ISSP i have calibration fail and i tried to run Board Test System (bts) but the gui can't detect the jtag cable
so i'm facing so many problems , i don't have much time and i need help
thanks
--- Quote Start ---
--- Quote End ---
Refer the User guide,
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-20120.pdf
For Daughter cards refer the following link,
https://www.altera.com/products/boards_and_kits/daughter-cards.html
--- Quote Start ---
--- Quote End ---
Have you installed the drivers, if not, Refer following link & install before using it,
https://www.altera.com/support/support-resources/download/drivers/dri-index.html
https://www.youtube.com/watch?v=wjwkdznh1py
Best Regards
Vikas Jathar
Hi ,
--- Quote Start ---
--- Quote End ---
there are no memory daughter cards for stratix 10
--- Quote Start ---
--- Quote End ---
and i already installed the driver and it is working correctly , i'm using it to download the bit stream
so same problems
thanks
