5921 Discussions
EPM1270M256C4N Alternate part
Monika
Please suggest EPM1270M256 CPLD alternate part in the same family.
EngWei_O_Intel
Hi there
Referring to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max2/max2_mii5v1.pdf
MAX II devices support vertical migration within the same package (for example, you can migrate between the EPM570, EPM1270, and EPM2210 devices in the 256-pin FineLine BGA package). Vertical migration means that you can migrate to devices whose dedicated pins and JTAG pins are the same and power pins are subsets or supersets for a given package across device densities.
You can always refer to pinout files below to check on the pins layout:
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
Eng Wei
Monika
Thanks for your reply.
However, I am seeing EPM1270M256C4N part into EOL category, so looking for its alternate part. Could you please suggest the equivalent alternate part number?
EngWei_O_Intel
hi there
We would suggest you to move to later devices such as Max V or Max 10. We can refer to link below for their information:
https://www.intel.com/content/www/us/en/products/details/fpga/max.html
There are product tables for each of the family as reference.
Eng Wei
Monika
We plan to use EPM1270M256C4N to support on-board USB Blaster II functionality as used in  MAX10 FPGA Development Kit (6XX-44292R) .
So, based on your inputs, plan to use Max 10 device 10M04DCF256I7G part in place of EPM1270M256C4N part to overcome the EOL issue.
Kindly review the part and let us know if 10M04DCF256I7G  part is okay to use.
EngWei_O_Intel
Hi Monika
Can you guide me to which PDN where the OPN is indicated to be EOL?
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/pcns-and-advisories.html#pdn
The closest device that I can find available is EPM1270M256I5N
where the existing code shall be able to be reused.
For newer devices, the migration have to be done and the source code have to be recompiled.
thanks.
Eng Wei
Monika
Please refer the link for the discontinued OPNs list: https://media.digikey.com/pdf/PCNs/Intel/PDN2041.pdf
I see both OPNs EPM1270M256C4N and EPM1270M256I5N in above list as discontinued parts.
EngWei_O_Intel
Hi Monika
I am not sure about the 3rd party link, I don't see similar information in the official link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pcn/pdn2041.pdf
Could you check with Marketing representative?
Eng Wei
EngWei_O_Intel
Hi Monika
I will be transitioning this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
