6338 Discussions
EPM7128AETI100-7N end of life
CaueCoelho
I work for Astom Group and we have in some old projects that is still used nowadays.
In one of these projects we are using the Altera EPM7128AETI100-7N, but the Alstom systems are signalizing that this item is obsolete.
So my question is, there are some substitute for this item?
Thank for the attention
Caue
ak6dn
Valued Contributor III
Intel/Altera has no direct substitute for this device. That series has been EOLed.
You might want to look at the Microchip ATF1508ASV series.
They offer direct compatibility to the EPM7128 series and have tools to convert Altera .POF to Microchip .JED files for programming.
I have used the ATF15xx series to replace several EPM7032S and EPM7064S parts using the existing programming files.
ak6dn
CaueCoelho
Hi ak6dn, thank you so much for this value information.!
This item seams to be perfect, even the I/O working voltage.
Help me with another issue, I'm not finding the Altera EPM7128AETI100-7N pin out, there is any special datasheet or a link with this 100-Pin TQFP pin-out?
Thank you once again.
ak6dn
Look here:   https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html
Search for 'EPM7128AE' there are links for PDF, TXT, and CSV files with device pinouts.
CaueCoelho
Thanks so much.!!!
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
CaueCoelho
Hi dear,
I'm back to question about the programmer.
There are some programmer for the Altera family that also can program the Microchip ATF1508ASV series?
Thank you
ak6dn
The programmer hardware itself is not the issue, it is just plain old JTAG protocol and signal levels.
You can connect up a microprocessor I/O ports to the JTAG lines and bit bang program the part, given the right software.
That being said, I opted to use the Atmel ATDH1150USB-K USB CPLD Programmer from Microchip.
It was the easiest solution in the short term, available at major distributors for about US$80.
Read about other solutions here:  https://microchipsupport.force.com/s/article/ISP-programmer-for-the-ATF15xx-CPLDs
