Edimax USB WiFi dongle?
Hello all,
I am trying to use the Edimax USB WiFi dongle with my DE0-Nano-Soc board. I have used this dongle on my Raspberry Pi boards, so I thought this would be compatible as well.
I am using a USB hub to share both the Bluetooth and Wifi dongles. Upon booting, the Nano-SoC does see the dongle but does not obtain an IP address. ifconfig doesn't show wlan0 in its configuration.
I have read in other Altera forums that a driver may be needed? I have used this interface "driveless" on my Raspberry Pi with no problems. Also, it appears that the /etc/network/interfaces file is configured correctly. Has anyone successfully use a USB WiFi adapter with their Nano-soc board?
Thanks in advance for the help...
Here is an excerpt of the boot process:
usb 1-1: new high-speed USB device number 2 using dwc2
INIT: version 2.88 booting
usb 1-1: New USB device found, idVendor=05e3, idProduct=0608
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB2.0 Hub
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
Starting Bootlog daemon: bootlogd.
usb 1-1.3: new high-speed USB device number 3 using dwc2
Configuring network interfaces... usb 1-1.3: New USB device found, idVendor=7392, idProduct=7811
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.3: Product: 802.11n WLAN Adapter
usb 1-1.3: Manufacturer: Realtek
usb 1-1.3: SerialNumber: 00e04c000001
wlan0: ERROR while getting interface flags: No such device
eth0: device MAC address 96:ca:7d:**:**:**
udhcpc (v1.20.2) started
usb 1-1.4: new full-speed USB device number 4 using dwc2
Sending discover...
usb 1-1.4: New USB device found, idVendor=0a12, idProduct=0001
usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
usb 1-1.4: Product: CSR8510 A10
Here is my /etc/network/interfaces file:
# /etc/network/interfaces -- configuration file for ifup(8), ifdown(8)
# The loopback interface
auto lo
iface lo inet loopback
# Wireless interfaces
iface wlan0 inet dhcp
wireless_mode managed
wireless_essid any
wpa-driver wext
wpa-conf /etc/wpa_supplicant.conf
iface atml0 inet dhcp
# Wired or wireless interfaces
auto eth0
iface eth0 inet dhcp
iface eth1 inet dhcp
# Ethernet/RNDIS gadget (g_ether)# ... or on host side, usbnet and random hwaddr
iface usb0 inet static
